> ALPHA-One > ALPHA-One (Single Page)
Edit page
The ALPHA-One is a Generative 7b LLM AI Agent based on StarPro64 board RISC-V based Single Board Computer with 20TOPS(int 8) NPU capability, and preinstalled 64G eMMC module contains 7b Deepseek/Owen LLM build in docker form.
The ALPHA-One
The ALPHA-One
Software
Releases
Production release build 20250627
Image for 64GB eMMC module
This build contains 7b QWen2 LLM. To access the web UI, open http://alpha-one.local:8000/
Download:
File information:
  • MD5 (GZip file): d62eeb1645c7b496a0815c4590f798c7
  • File Size: 18.10 GB
UserPassword
eswineswin
Image for 32GB eMMC module and above
This is the early test build that contains both 7b Deepseek and QWen2 LLM build, OS based on ROCKOS. For larger than 32GB eMMC, please use gpart to extend the file partition.
Download:
File information:
  • MD5 (GZip file): 6669a436104e97e2ad90679e06f62d78
  • File Size: 18.21 GB
UserPassword
eswineswin
Usage
To explore LLM, use terminal program and execute below command lines:
DeepSeek 7b LLM command:
$ sudo /opt/eswin/sample-code/npu_sample/qwen_sample/bin/es_qwen2 /opt/eswin/sample-code/npu_sample/qwen_sample/src/deepseek_r1_distill_qwen_7b/config.json
Qwen2 7bLLM command:
$ sudo /opt/eswin/sample-code/npu_sample/qwen_sample/bin/es_qwen2 /opt/eswin/sample-code/npu_sample/qwen_sample/src/qwen2_7b/config.json
Qwen2 0.5bLLM command:
$ sudo /opt/eswin/sample-code/npu_sample/qwen_sample/bin/es_qwen2 /opt/eswin/sample-code/npu_sample/qwen_sample/src/qwen2_0_5b/config.json
SDKs
The SDK documents can be found under https://files.pine64.org/SDK/StarPro64/docs.7z (some are in Chinese).
File information:
  • MD5 (7-Zip file): 8ee9b660c336d9979191d212e9826226
  • File Size: 34 MB
SDK Release:
LLM and tools release:
Specifications
Main Board and SoC Specification
EIC7700X block diagram
Features
  • 32GB 64bits LPDDR5@6400MHz RAM Memory.
  • 64GB eMMC preinstalled with 7b Deepseek/Qwen LLM
Case
  • CNC from single Aluminum block
  • Passive cooling, built-in heat pipe that directly contact with SoC
Network
  • Dual 10/100/1000 Mbps Ethernet
  • 2.4GHz/5GHz MIMO WiFi 802.11 b/g/n/ac/ax with Bluetooth 5.3
Expansion Ports
  • 2× USB3.0 Dedicated Host port
  • 2× USB2.0 Shared Host port
  • 3.5mm audio Jack with mic in
Certifications
  • Not yet available
Potential Improvement
  • Current 7bLLM throughput is around 3.5 tokens/second using docker form, potential improve up to 10 tokens/second when operates LLM in native mode.
  • Potential increase LLM capability from 7b to 15b with system software optimization
  • If ALPHA-One proven its potential, consider release ALPHA-Two which can host up to 30b LLM
