> PINE H64 Model A > PINE H64 Model A (Single Page)
Edit page
The PINE H64 Model A
The PINE H64 Model A is a discontinued Single Board Computer by PINE64. It is powered by an Allwinner “H6” Quad-Core ARM Cortex A53 64-Bit Processor with a MALI T-722 GPU.
Board Features
Dimensions
Board dimensions: 133mm x 80mm x 19mm
Power
Input power: DC 5V @ 3A, 3.5mm OD/ 1.35mm ID DC jack connector, Euler connector
Video
  • Digital Video 4KP60 (Type A - full)
Audio
Network
  • 10/100/1000 Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1 (optional)
Storage
  • USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins “Pi2” GPIO Header
  • mini PCIe connector
SoC and memory specifications
The PINE H64 Model A is based on the Allwinner H6.
  • Quad-core ARM Cortex-A53 Processor@1488Mhz footnote:[see Cortex-A53 on arm.com]
  • Trustzone technology supported
  • Support Large Physical Address Extensions (LPAE)
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • ARM Mali T-720MP2 Dual-core GPU footnote:[see Mali-T720 on arm.com]
  • Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
  • Supports ATSC (Adaptive Scalable Texture Compression)
  • Supports FAST (4x) FSAA, IO Coherency
  • Floating point operation greater than 70 GFLOPS
  • RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
  • Storage Memory: PINE H64 boards have a built-in 128Mb SPI Flash memory and can use bootable eMMC modules, bootable microSD cards or USB-attached storage.
Software
Armbian
Armbian is a Linux distribution designed for ARM boards. They are usually Debian or Ubuntu flavored.
Download:
Default credentials
root1234
Linux BSP SDK
The Linux BSP Kernel version 4.9
Download:
Linux BSP Kernel ver 3.10 Lichee ver 1.1
Linux BSP Kernel ver 3.10 Lichee ver 1.0
Mali-T720 driver
A good DRM PowerPoint presentation by Free Electron here and the DRM video presentation by Free Electron here.
32-bit Wayland MALI Driver:
Further information
Datasheets
Allwinner H6 SoC information:
X-Powers AXP805 PMU (Power Management Unit) information:
LPDDR3 (178 Balls) SDRAM:
eMMC information:
SPI NOR Flash information:
Ethernet PHY information:
Wifi/BT module information:
miniPCIe SATA module information:
Enclosure information:
Remote control button mapping
Schematics and Certifications
PINE H64 Board Schematic:
PINE H64 Certification:
  • [Not yet available]
