Board Features
Dimensions
Board dimensions: 85mm x 56mm x 18.8mm
Power
Input power: DC 5V @ 3A, 3.5mm OD/ 1.35mm ID DC jack connector
Video
- Digital Video 4KP60 (Type A - full)
Audio
- 3.5mm stereo earphone/microphone plug
Network
- 10/100/1000 Mbps Ethernet
- WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1
- MHF1 RF coaxial connector for external BT/wifi antenna
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
- RTC - Real Time Clock Battery Connector
- Wifi/BT Module Header - SDIO 3.0 and UART
- 2x20 pins “Pi2” GPIO Header
- 3x3 pins “EXT” Header giving console, power switch and reset switch access
Console
- The console UART is available on the 6-pin header connector between the HDMI and headphone jacks. The pins are on the front row, closer to the board’s edge: TX, RX, GND, from left (HDMI) to right (headphone).
- The default standard is 8,n,1 at 115200bps.
SoC and memory specifications
The PINE H64 Model B is based on the Allwinner H6.
- Quad-core ARM Cortex-A53 Processor@1488Mhz footnote:[see Cortex-A53 on arm.com]
- A power-efficient ARM v8 architecture
- 64 and 32bit execution states for scalable high performance
- Trustzone technology supported
- Support NEON Advanced SIMD (Single Instruction Multiple Data) instruction for acceleration of media and signal processing function
- Support Large Physical Address Extensions (LPAE)
- VFPv4 Floating Point Unit
- 32KB L1 Instruction cache and 32KB L1 Data cache
- 512KB L2 cache
GPU Architecture
- ARM Mali T-720MP2 Dual-core GPU footnote:[see Mali-T720 on arm.com]
- Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
- Supports ATSC (Adaptive Scalable Texture Compression)
- Supports FAST (4x) FSAA, IO Coherency
- Floating point operation greater than 70 GFLOPS
- RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
- Storage Memory: PINE H64 boards have a built-in 128Mb SPI Flash memory and can use bootable eMMC modules, bootable microSD cards or USB-attached storage.
Table of contents
