> PINE H64 Model B > PINE H64 Model B (Single Page)
Edit page
The PINE H64 Model B
The PINE H64 Model B is a Single Board Computer by PINE64. It is powered by an Allwinner “H6” Quad-Core ARM Cortex A53 64-Bit Processor with a MALI T-722 GPU. The PINE H64 is equipped with up to 3GB of LPDDR3 PC-1600 system memory and 128 Mbit of SPI boot Flash. There is also an optional eMMC module (up to 128GB) and a microSD slot for booting. The board is equipped with an onboard 802.11n Wifi/BT chipset, one USB 3.0 host port, two USB 2.0 host ports, Gigabit Ethernet, a PI-2 GPIO bus, an Euler GPIO bus as well as many other peripheral device interfaces such as UART, SPI, and I^2^C.
Board Features
Dimensions
Board dimensions: 85mm x 56mm x 18.8mm
Power
Input power: DC 5V @ 3A, 3.5mm OD/ 1.35mm ID DC jack connector
Video
  • Digital Video 4KP60 (Type A - full)
Audio
Network
  • 10/100/1000 Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1
  • MHF1 RF coaxial connector for external BT/wifi antenna
Storage
  • USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins “Pi2” GPIO Header
  • 3x3 pins “EXT” Header giving console, power switch and reset switch access
Console
  • The console UART is available on the 6-pin header connector between the HDMI and headphone jacks. The pins are on the front row, closer to the board’s edge: TX, RX, GND, from left (HDMI) to right (headphone).
  • The default standard is 8,n,1 at 115200bps.
SoC and memory specifications
The PINE H64 Model B is based on the Allwinner H6.
  • Quad-core ARM Cortex-A53 Processor@1488Mhz footnote:[see Cortex-A53 on arm.com]
  • Trustzone technology supported
  • Support Large Physical Address Extensions (LPAE)
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • ARM Mali T-720MP2 Dual-core GPU footnote:[see Mali-T720 on arm.com]
  • Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
  • Supports ATSC (Adaptive Scalable Texture Compression)
  • Supports FAST (4x) FSAA, IO Coherency
  • Floating point operation greater than 70 GFLOPS
  • RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
  • Storage Memory: PINE H64 boards have a built-in 128Mb SPI Flash memory and can use bootable eMMC modules, bootable microSD cards or USB-attached storage.
Software
Releases
The following releases are for the PINE H64 Model B
Linux
Armbian
Armbian is a Linux distribution designed for ARM boards. They are usually Debian or Ubuntu flavored.
Download:
Manjaro ARM
Manjaro is a user-friendly Linux distribution based on the independently developed Arch operating system. To learn more about Manjaro please visit the Manjaro Forum. Download:
DietPi
DietPi is a lightweight yet easy to setup and feature-rich Linux distribution, based on Debian. To find out more about DietPi, please visit the official documentation. Discuss the PINE H64 build on the PINE64 forum thread.
Download:
Default credentials
rootdietpi
LibreELEC
LibreELEC is a “Just enough OS” Linux distribution combining the Kodi media center with an operating system.
Download:
  • Daily builds (look for look for LibreELEC-H6.arm-xxx-nightly-xxxxxxxx-xxxxxxx-pine-h64-model-b.img.gz]
Notes:
  • Supports microSD card and eMMC boot
BSD
FreeBSD
FreeBSD is an operating system used to power modern servers, desktops, and embedded platforms. To learn more about FreeBSD, please visit FreeBSD main page.
Instructions:
Notes:
  • FreeBSD supports booting from the microSD card
NetBSD
NetBSD is a free, fast, secure, and highly portable Unix-like Open Source operating system. To learn more about NetBSD please visit NetBSD main page.
Download:
Notes:
  • NetBSD supports booting from the microSD card
Default credentials
root (root user and SSH)[none]
Linux BSP SDK
Linux BSP Kernel 4.9
Download:
  • Direct download from pine64.org (5.04GB, MD5 of the TAR-XZ file 06B675B1C217D4CC6A21FF320DA250C1)
Android SDK
Android Pie 9.0 SDK version 1.0
  • Direct download from pine64.org (29.14GB, MD5 of the TAR-XZ file 734B4DBB03CAF82A4E955F7E83DE0C65)
Further information
Datasheets
Allwinner H6 SoC information:
X-Powers AXP805 PMU (Power Management Unit) information:
LPDDR3 (178 Balls) SDRAM:
eMMC information:
SPI NOR Flash information:
Ethernet PHY information:
Wifi/BT module information:
Remote control button mapping:
Schematics and Certifications
PINE H64 board schematics:
PINE H64 Model B certification:
Mali-T720 driver
A good DRM PowerPoint presentation by Free Electron here and the DRM video presentation by Free Electron here.
32-bit Wayland MALI Driver:
64-bit Wayland MALI Driver:
