Qi Wireless Charging Add-on
Warning
Possible safety hazard: If the wireless charging chip fails for some reason, do not plug the phone in to charge via USB-C. Take the back case off first. It is possible that power gets fed into the chip, causing it to overheat, possibly causing damage to the phone and creating a fire-hazard.
Album of damage caused by reverse current: https://imgur.com/a/dJsp5wD
Until the cause of this is determined, it is recommended NOT to use the wireless charging add-on.
Uses the pogo pins to supply Qi Wireless and Wireless Power Consortium compatible charging. No software required.
Schematics and Datasheet
Schematic:
Datasheet:
Table of contents
