> PINE A64-LTS > Pine A64-LTS (Single Page)
Edit page
The PINE A64-LTS
The PINE A64-LTS
The PINE64-LTS is the long term supply version of the PINE A64 (+), PINE64’s first single board computer, powered by Allwinner’s A64 quad-core ARM Cortex A53 64-Bit SoC. There are many operating systems available for the PINE A64-LTS created by the open source community and various partner projects. The PINE A64-LTS is guaranteed to be supplied until the year 2025 at the very least.
Board features
Layout
Model “A” Baseboard Dimensions: 133mm x 80mm x 19mm
Video
  • Digital Video (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion ports
  • 2x20 pins “Pi2” GPIO Header
  • 2x17 pins “Euler” GPIO Header
  • 2x5 pins “EXP” Console Header
Power
Input Power: DC 5V @ 2A, 3.7V Li-Ion battery connector, 3.5OD/1.35ID Barrel DC Jack connector, Euler connector
Accessories
Please see Accessories Step by Step Guides for a list of guides for Pine A64 accessories; there you can find instructions and guides about the following:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more)
Further information
Datasheets
Allwinner A64/R18 SoC information:
X-Powers AXP803 PMU (Power Management Unit) information:
LPDDR3 information:
eMMC information:
SPI NOR Flash information:
5MPixel CMOS Camera module information:
Early version Camera module information:
LCD Touch Screen Panel information:
Lithium Battery information:
Ethernet PHY information:
Wifi/BT module information:
Enclosure information:
Connector information:
Remote control button mapping:
Other resources
Pine A64 POT
Schematics and certifications
  • Model “A” Baseboard Dimensions: 133mm x 80mm x 19mm
Schematics:
Pine A64-LTS schematic:
Pine A64-LTS V2 schematic:
SoC and Memory Specification
The PINE A64-LTS is based on the Allwinner A64/R18. The R18 and A64 are identical SoCs but the is R18 committed for a 10 years supply by the vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: 128Mb SPI Flash and optional eMMC module from 16GB up to 128GB
Software
The SOPINE operating system images are compatible with PINE A64-LTS. Under Software you will find a complete list of currently supported operating system images, which work with the PINE A64-LTS, as well as other related software.
Below is a list of links to the build sources and environments for some operating system images. Some of them are labelled as beta or nightly builds, which means they are fit for testing purposes only. Those images should be used at your own risk and are not fit for regular use.
