Note: Due to a cluster outage, we currently host the new beta website. Bugs expected, details.
Internal layout
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory module (26; Note: Some datasheets indicate a low supported number of mating cycles.)
  • WiFi/BT module (27)
There are two switches on the main board: disabling the eMMC module (24), and enabling serial console UART (9) via headphone jack.
The Reset and Recovery buttons (28): the reset button performs an immediate reset of the laptop. The Recovery button is used to place the device in maskrom mode. This mode allows flashing eMMC using Rockchip tools (e.g. rkflashtools).
PBPL S
Key Internal Parts
+ Numbered parts classification and description
Number
Type
Descriptor
scope=row
1
Component
RK3399 System-On-Chip
scope=row
2
Socket
PCIe x4 slot for optional NVMe adapter
scope=row
3
Socket
Speakers socket
scope=row
4
Socket
Touchpad socket
scope=row
5
Component
Left speaker
scope=row
6
Connector
Power bridge connector
scope=row
7
Socket
Keyboard Socket
scope=row
8
Component
Optional NVMe SSD adapter
scope=row
9
Switch
UART/Audio switch - enables serial console UART via headphone jack
scope=row
10
Socket
Power bridge socket
scope=row
11
Socket
Battery socket
scope=row
12
Component
Touchpad
scope=row
13
Component
Battery
scope=row
14
Component
Right speaker
scope=row
15
Socket
MicroSD card slot
scope=row
16
Socket
Headphone / serial console UART jack
scope=row
17
Socket
USB 2.0 Type A
scope=row
18
Socket
Daughterboard-to-mainboard ribbon cable socket
scope=row
19
Cable
scope=row
20
Component
microphone
scope=row
21
Component
LPDDR4 RAM
scope=row
22
Socket
Mainboard-to-daughterboard ribbon cable socket
scope=row
23
Socket
Microphone socket
scope=row
24
Switch
Switch to hardware disable eMMC
scope=row
25
Antenna
BT/WiFI antenna
scope=row
26
Component
scope=row
27
Component
BT/WiFi module chip
scope=row
28
Buttons
Reset and recovery buttons
scope=row
29
Component
SPI flash storage
scope=row
30
Socket
eDP LCD socket
scope=row
31
Socket
Power in barrel socket
scope=row
32
Socket
USB 3.0 Type A
scope=row
33
Socket
USB 3.0 Type C
