Schematics and certifications
- Model “A” Baseboard Dimensions: 133mm x 80mm x 19mm
- Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
SOEDGE Model “A” Baseboard schematics and PCB board resources:
- SOEDGE Model “A” Baseboard Schematic 20210223 PDF file
- SOEDGE Model “A” Baseboard 20210223 PCB Component Placement Top PDF file
- SOEDGE Model “A” Baseboard 20210223 PCB Component Placement Bottom PDF file
SOEDGE module together with the baseboard certification:
- Disclaimer: Please note that SOEDGE module is not a “final” product and in general certification is not necessary. However, SOEDGE module still submits the mpdel A baseboard for FCC, CE, and ROHS certifications and obtain the certificates to prove that can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
- Not yet available
Ethernet PHY information:
