SOEDGE Baseboard (Single Page)
The SOEDGE Baseboard
The SOEDGE Baseboard is a baseboard that hosts the SOEDGE compute module and turns it into a full single board computer. Makers can use this baseboard as reference to develop their own PCBs and for software development during early stages for custom hardware or PCB development.
Features
Expansion ports
- DSI - Display Serial Interface, 4 lanes MiPi, up to 1080P
- TP - Touch Panel Port, SPI with interrupt
- RTC - Real Time Clock Battery Connector
- VBAT - Lithium Battery Connector with temperature sensor input
- Wifi/BT Module Header - SDIO 3.0 and UART
- 2x20 pins “Pi2” GPIO Header
- PCIe 2x open ended slot
Schematics and certifications
- Model “A” Baseboard Dimensions: 133mm x 80mm x 19mm
- Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
SOEDGE Model “A” Baseboard schematics and PCB board resources:
- SOEDGE Model “A” Baseboard Schematic 20210223 PDF file
- SOEDGE Model “A” Baseboard 20210223 PCB Component Placement Top PDF file
- SOEDGE Model “A” Baseboard 20210223 PCB Component Placement Bottom PDF file
SOEDGE module together with the baseboard certification:
- Disclaimer: Please note that SOEDGE module is not a “final” product and in general certification is not necessary. However, SOEDGE module still submits the mpdel A baseboard for FCC, CE, and ROHS certifications and obtain the certificates to prove that can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
- Not yet available
Ethernet PHY information:
Network
- 10/100/1000Mbps Ethernet
- WiFi 802.11 b/g/n with Bluetooth 4.0 (optional)
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- USB - 2 USB2.0 Host port
Specifications
- Gigabit Ethernet
- HD Digital Video Out
- 2x USB 3.0 Host
- Euler Bus
- Expansion Bus
- PI-2 Bus
- PCIe 4X open-ended header
- Touch Panel Port (TP)
- Display Serial Interface (DSI) Port
- IR R/X Port
- Real Time Clock Port (RTC)
- Lithium Battery Port
- SMOS Sensor Interface Port
- Optional AC WiFi + BT 5.0 module expansion module
- Headphone Jack
- 5.5″ Barrel Power (12V 3A/5A) Port
- Not yet available
