> Yuzuki Avaota A1 > Yuzuki Avaota A1 (Single Page)
Edit page
The PineVoice
The PineVoice
The Yuzuki Avaota-A1 is an ARM64 based Single Board Computer powered by an Allwinner A527 Octa-Core ARM Cortex-A55 64-Bit CPU @2.0GHz, ARM Mali G56 GPU and RISC-V XuanTie E906 CPU@200MHz. It provides an onboard eMMC, MicroSD Card slot, PCI-e, Pi-2 Bus, USB 3.0, and many other peripheral interfaces for makers to integrate with sensors and other devices.
Further information
Datasheets
Allwinner A527 SoC information:
X-Power PMU information:
LPDDR4 (200 Balls) SDRAM:
eMMC information:
Ethernet related info:
WiFi/BT module info:
Schematics and certifications
Avaota A1 SBC dimensions
Input Power: DC 12V @ 3A 5.5mmOD/2.1mmID center-positive Barrel DC Jack connector
Schematic:
Board map of connectors with schematic v1.1 identifiers:
Avaota A1 SBC layout
Certifications:
  • Disclaimer: Please note that PINE64 SBC is not a “final” product and in general certification is not necessary. However, PINE64 still submits the SBC for FCC, CE, and ROHS certifications and obtain the certificates to prove that the SBC board can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
  • Not yet available
Specifications
SoC and Memory Specification
Allwinner T527 A527 block diagram
  • Quad-core ARM Cortex-A55 at 2.0 GHz
  • Integrated 64KB L2 instruction cache and 128KB L2 data cache per cluster
  • 1MB unified system L3 cache
GPU Architecture
  • Mali-G57 Valhall GPU@850MHz
  • Supports Vulkan 1.1
  • Supports OpenCL 1.1, 1.2, 2.0 Full Profile
  • Supports Renderscript
  • L2 Cache Configurable 64KB – 512KB ** 64KB-128KB for 1-Core ** 128KB-256KB for 2-Core ** 256KB for 3-Core ** 1x256KB-2x256KB for 4-Core ** 2x256KB-2x512KB for 5-Core and 6-Core configurations
  • Supports 3400 Mpix/s fill rate when at 850MHz clock frequency
  • Supports 243.2 GLOP/s when at 850MHz clock frequency for peak single precision (FP32) performance
  • LPDDR4 RAM Memory Variants: 2GB and 4GB.
Board Features
Video
  • H.264/AVC Base/Main/High/High10 profile @ level 5.1; up to 4K×2K @ 30fps
  • H.265/HEVC Main/Main10 profile @ level 5.1 High-tier; up to 4K×2K @ 60fps
Audio
  • 3.5mm audio Jack
Network
  • Dual 10/100/1000Mbps Ethernet
  • 2.4GHz/5Ghz MIMO WiFi 802.11 b/g/n/ac with Bluetooth 5.2
Storage
  • on-board 128Mbit (16MByte) XSPI NOR flash memory - bootable
  • microSD - bootable, supports SDHC and SDXC and storage up to 256GB
  • eMMC - bootable on-board 16GB or 32GB
Expansion Ports
  • 2×20 pins “Pi2” GPIO Header
Avaota-A1 40 pin connector diagram
  • 4 lane MiPi DSI port for LCD panel
  • 4 lane MiPi CSI port for camera module
  • 1× USB3.0 OTG port
  • 1× USB2.0 Host port
  • 1× USB2.0 OTG port
  • 1× CAN port
Software
Software releases
These releases are still in beta state and are only fit for development purposes.
OpenWrt Image Build
Armbian Mainline Linux OS Image Build
  • Source code available at https://github.com/pine64/build/releases, others are welcome to fork and enhance.
  • Attach USB keyboard, then follow onboard small LCD screen message to complete first setup
  • After the initial setup, please allow some time for the download of the HA (Home Assistant) image
  • PineDio Zigbee dongle driver already included
  • For the board with 2GB of memory, please only use OS build with Picoclaw version.
The following are 2026.06.05 builds
The following are 2026.05.21 builds
Avaota OS Legacy Linux Image Build
The following OS build is derived from the Allwinner BSP
Android 13 Image Build
Note: “eng” build enable root and log for development or hacking purpose, “user” build disable root and log as release version
Android 13 SDK
  • Direct Download from pine64.org (62.28GB, MD5 f565ff9d0f712ca9c8131c69011379cf)
Resources and Articles
